Aller au contenu principal
Comfort Zone CZ6C Fan Blades Replacement
Ce dont vous avez besoin
  1. Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: étape 1, image 1 de 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: étape 1, image 2 de 3 Comfort Zone CZ6C Fan Blades Replacement, Fan Blades: étape 1, image 3 de 3
    • The metal cage is kept in place by three plastic tabs on the plastic body. Focus your pulling around these tabs to make the job easier.
    • In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
    • Now work your way around the edge of the fan cage and pull it away from the plastic body.
  2. Comfort Zone CZ6C Fan Blades Replacement: étape 2, image 1 de 2 Comfort Zone CZ6C Fan Blades Replacement: étape 2, image 2 de 2
    • To remove the fan blade, reach behind it and slowly pull it towards you.
    • If the fan blade axle has any hair or dirt, then clean it with a cloth to avoid further fan blade blockage.
    • If you are having difficulty removing the fan blade, then generously apply WD-40 to the fan blade axle.
Samantha Galicinao
Membre depuis le 04/07/15
289 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-5, Forte Spring 2015 Membre de l'équipe Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 membres
5 tutoriels rédigés
2 commentaires
Where does one buy the replacement blades?
Frank Gould - Réponse
where does one buy the replacement blades??
Luis Marrero - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 33
Total : 5,845
