Aller au contenu principal
Comfort Zone CZ6C Switch Replacement
Ce dont vous avez besoin
  1. Comfort Zone CZ6C Switch Replacement, Switch: étape 1, image 1 de 3 Comfort Zone CZ6C Switch Replacement, Switch: étape 1, image 2 de 3 Comfort Zone CZ6C Switch Replacement, Switch: étape 1, image 3 de 3
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
  2. Comfort Zone CZ6C Switch Replacement: étape 2, image 1 de 2 Comfort Zone CZ6C Switch Replacement: étape 2, image 2 de 2
    • Remove the plastic cover on the switch by pulling it apart from the the back panel.
  3. Comfort Zone CZ6C Switch Replacement: étape 3, image 1 de 1
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
  4. Comfort Zone CZ6C Switch Replacement: étape 4, image 1 de 2 Comfort Zone CZ6C Switch Replacement: étape 4, image 2 de 2
    • Cut the green and yellow wire as close to the switch connection as possible.
  5. Comfort Zone CZ6C Switch Replacement: étape 5, image 1 de 3 Comfort Zone CZ6C Switch Replacement: étape 5, image 2 de 3 Comfort Zone CZ6C Switch Replacement: étape 5, image 3 de 3
    • Strip the green and yellow wire about two centimeters from where it was just cut.
  6. Comfort Zone CZ6C Switch Replacement: étape 6, image 1 de 3 Comfort Zone CZ6C Switch Replacement: étape 6, image 2 de 3 Comfort Zone CZ6C Switch Replacement: étape 6, image 3 de 3
    • Unscrew the switch from the back panel and remove it.
  7. Comfort Zone CZ6C Switch Replacement: étape 7, image 1 de 3 Comfort Zone CZ6C Switch Replacement: étape 7, image 2 de 3 Comfort Zone CZ6C Switch Replacement: étape 7, image 3 de 3
    • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
James Abundis
Membre depuis le 04/08/15
169 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-5, Forte Spring 2015 Membre de l'équipe Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 membres
5 tutoriels rédigés
Un commentaire
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 2,397
