Aller au contenu principal
Comment forcer le redémarrage de l'iPhone X
Ce dont vous avez besoin
  1. Comment forcer le redémarrage de l'iPhone X, Comment forcer le redémarrage de l'iPhone X: étape 1, image 1 de 1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
  2. Comment forcer le redémarrage de l'iPhone X: étape 2, image 1 de 1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    please what do i do when my iphone X shows Up the Itunes Sign and needs to be Reset ….. And please how do i reset it
    nana dollar - Réponse
    I’ve been trying to restart my iPhone X since yesterday night… doing it the way I always do (volume up or down and hold side button) and NOTHING. I just came to look for help online and all the same thing. BUT I found your way… and I got my phone back!!!! It was frozen on the same screens, unresponsive. THANK YOU!!!
    Karina Ardizzi - Réponse
    It didn’t work :(. I’m pressing the button….
    Susie Lopez - Réponse
    how to know what happen with my iPhone X. dark only could not charge. I did not used a week.
    Bunyavasi Malherbe - Réponse
    Nope... still frozen cycle....
    Candy Ogden - Réponse
    Yay!! Finally found a simple and easy fix!! and it worked
    Deberah Blair - Réponse
    Still pressing didn't show on
    akinyemi taiwo - Réponse
    Merci beaucoup
    MBD - Réponse
    Merci beaucoup. mais je une question par exemple si je veux regarder une vidéo je n'arrive pas pourquoi?
    MBD - Réponse
Ligne d'arrivée
132 autres ont terminé cette réparation.
14 commentaires
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
Satit Jan - Réponse
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
Siraj Munir - Réponse
good share. thanks.
MelissaR - Réponse
What is the other way?
sa sas - Réponse
will it delete all data from my iPhone?
_TR0xuu_ - Réponse
No, it will only reboot the operating system. Your data and settings will persist.
Arno Keifl -
Génial. Ca a bien fonctionné même sur un Iphone 12
Emmanuel - Réponse
Didn’t work. Now what?
Shawn Leimbach - Réponse
It's not working for me, please anymore ideas?
Christiana Linus Ekpo - Réponse
Apple logo didn't show on screen,just empty battery sign
May Weather - Réponse
hi this literally saved my life thank you so so much!
bk03 - Réponse
Face ID has stopped after changing the screen, how to fix
ALKAMBASHE EST - Réponse
You have to have a machine that puts the old serial number on the new part so the phone recognizes it. It's called "parts pairing" and it's why Apple sucks. I have seen someone do it with an EEPROM reader/writer but I could not find one for purchase so you would need to go to an Apple-authorized repair tech to have your new parts reserialized.
Sandy Andlow -
enormous thanks even if i was sceptic, incredible life hack huuuuuuuge thanks
Alexandre Mathias Donnat - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 30
7 derniers jours : 177
30 derniers jours : 720
Total : 364,644
