Introduction
Il est difficile de voir à travers des verres de lunettes rayés. Heureusement, on peut réparer les rayures pour rendre aux verres leur état d'origine. Gardez vos lunettes en parfait état avec ces quelques étapes.
Ce dont vous avez besoin
Placez les lunettes, la cire et le tissu sur une surface plane.
Pour les rayures particulièrement profondes ou persistantes, répétez ces étapes jusqu'à réparation des rayures en question.
56 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Suzanne Tessier nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
24 commentaires
Stupid is as stupid does! Think about it. A scratch is a certain width, when you polish it you are just grinding off the edges of the scratch and actually making it wider. So unless you are capable of removing all the surrounding material to the depth of the deepest part of the scratch AND maintaining the profile to within a very very small tolerance then this just WILL NOT work. Filling the scratch with wax cannot work either as wax does not have the same refractive index as the lens material. Conclusion: take care of your glasses and if you are careless enough to damage them it's your own fault, accept responsibility and replace them.
This sounds like "I've not tried this but I've thought about it for a few minutes and this is what I think will happen". Very short on evidence.
steve -
Wow!!! Just couldn’t help yourself could you. Perhaps you’ve heard “If you can’t say something nice say nothing at all”! Grow up without doing it at someone elses expense.
Yaya -
Obviously, this person has never made a mistake and is absolutely perfect in every way.
