Introduction
The switch guard is there to prevent accidental activation of the mixer, something which is critical in a commercial environment. The switch guard can be damaged due to a strong impact to the side of the mixer. This guide will provide a detailed step-by-step instructions on how to replace the switch guard for the KitchenAid Commercial 8qt Mixer.
Ce dont vous avez besoin
Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
Remove the trim band.
Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
Remove the motor housing by lifting it straight up.
Using a #2 Phillips screwdriver, remove the single screw attaching the switch guard to the mixer body.
