Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Commercial Electric MMA-8302R Multimeter Fuse Replacement
Ce dont vous avez besoin
  1. Commercial Electric MMA-8302R Multimeter Fuse Replacement, Turn off multimeter and unplug the two leads.: étape 1, image 1 de 2 Commercial Electric MMA-8302R Multimeter Fuse Replacement, Turn off multimeter and unplug the two leads.: étape 1, image 2 de 2
    • Turn the dial until the little green mark is set on the "OFF" option. Next disconnect the two testing leads by simply pulling them away from the body. Set these aside for later.
  2. Commercial Electric MMA-8302R Multimeter Fuse Replacement, Unscrew the four phillips screws that hold the back panel: étape 2, image 1 de 3 Commercial Electric MMA-8302R Multimeter Fuse Replacement, Unscrew the four phillips screws that hold the back panel: étape 2, image 2 de 3 Commercial Electric MMA-8302R Multimeter Fuse Replacement, Unscrew the four phillips screws that hold the back panel: étape 2, image 3 de 3
    • Unscrew the four Phillips screws that hold the back panel and carefully open it from either side and lay it besides the main body, try not to break the top led cable.
    • Disconnect the top led cable from the PCB and move everything aside.
  3. Commercial Electric MMA-8302R Multimeter Fuse Replacement, Swap out the fuses: étape 3, image 1 de 1
    • Swap the blown fuses out for new ones and you're done!
4 autres ont terminé cette réparation.
DeZom
Membre depuis le 02/12/22
955 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 64
Total : 2,416
