Introduction
A 3AG fuse is a glass - bodied fuse designed to break an electric circuit if the current exceeds safety levels in a Commodore 64 device
Ce dont vous avez besoin
Étape 1 Removing screws
Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
1. Remove three 6.75mm ph2 screw heads from the casing
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Find the 3AG fuse located next to the joystick ports and On/Off switch
3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
4 autres ont terminé cette réparation.
