Introduction
The Central Processing Unit (CPU) or Micro Processing Unit (MPU) is the 8-bit processor for the Commodore 64.
Ce dont vous avez besoin
Étape 1 Removing screws
Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme en cours.
1. Remove three 6.75mm ph2 screw heads from the casing
1. Detach the multi-colored wire bundles connected to the motherboard.
3. Loosen the CPU chip with a Phillips screwdriver. Then use your hand to pry up the CPU chip from the motherboard.
5 autres ont terminé cette réparation.
Un commentaire
there are two problems
1. Use an spudger for lifting the C.P.U instead of an screw driver bit to help alleviate concerns of bending the pins,
2. There is an step missing which involves cutting the tape seen here.
- Jordan .F
