Aller au contenu principal
Compaq Evo N1000v LED Cover Replacement
Ce dont vous avez besoin
  1. Compaq Evo N1000v LED Cover Replacement, LED Cover: étape 1, image 1 de 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v LED Cover Replacement: étape 2, image 1 de 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v LED Cover Replacement: étape 3, image 1 de 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v LED Cover Replacement: étape 4, image 1 de 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v LED Cover Replacement: étape 5, image 1 de 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v LED Cover Replacement: étape 6, image 1 de 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v LED Cover Replacement: étape 7, image 1 de 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v LED Cover Replacement: étape 8, image 1 de 2 Compaq Evo N1000v LED Cover Replacement: étape 8, image 2 de 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
kim
Membre depuis le 04/14/10
59 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 29-74, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 2,750
