Aller au contenu principal
Compaq Mini 110 Hard Drive Replacement
Ce dont vous avez besoin
  1. Compaq Mini 110 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Compaq Mini 110 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
  2. Compaq Mini 110 Hard Drive Replacement: étape 2, image 1 de 3 Compaq Mini 110 Hard Drive Replacement: étape 2, image 2 de 3 Compaq Mini 110 Hard Drive Replacement: étape 2, image 3 de 3
    • Push both tabs inward simultaneously and slide the battery out.
  3. Compaq Mini 110 Hard Drive Replacement, RAM: étape 3, image 1 de 2 Compaq Mini 110 Hard Drive Replacement, RAM: étape 3, image 2 de 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
  4. Compaq Mini 110 Hard Drive Replacement: étape 4, image 1 de 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
  5. Compaq Mini 110 Hard Drive Replacement, Keyboard: étape 5, image 1 de 2 Compaq Mini 110 Hard Drive Replacement, Keyboard: étape 5, image 2 de 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
  6. Compaq Mini 110 Hard Drive Replacement: étape 6, image 1 de 2 Compaq Mini 110 Hard Drive Replacement: étape 6, image 2 de 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
  7. Compaq Mini 110 Hard Drive Replacement: étape 7, image 1 de 2 Compaq Mini 110 Hard Drive Replacement: étape 7, image 2 de 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
  8. Compaq Mini 110 Hard Drive Replacement: étape 8, image 1 de 2 Compaq Mini 110 Hard Drive Replacement: étape 8, image 2 de 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
  9. Compaq Mini 110 Hard Drive Replacement, Hard Drive: étape 9, image 1 de 1
    • Remove the three screws holding the panel in place.
  10. Compaq Mini 110 Hard Drive Replacement: étape 10, image 1 de 2 Compaq Mini 110 Hard Drive Replacement: étape 10, image 2 de 2
    • Pull up on the tab to remove the hard drive.
15 autres ont terminé cette réparation.
alea
Membre depuis le 10/06/10
1 405 Réputation
14 tutoriels rédigés
Équipe
Cal Poly, Team 22-2, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 membres
20 tutoriels rédigés
2 commentaires
still cannot remove back of my compacq mini. i have taken all screws out as told but back refuses to part.
madudman - Réponse
still cannot remove back of my compact after removing all screws. are ther any more hidden clips ? mike
madudman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 34
Total : 38,858
