Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
If your system overheats, in this video we will show you
how to disassemble / take apart Compaq Presario CQ58, clean the Cooling / Fan System and change the thermal Compound / Grease.
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
  1. Switch-off the laptop and remove the battery. Remove the memory cover. Remove the memory cover.
    • Switch-off the laptop and remove the battery.
    • Remove the memory cover.
  2. Remove the HDD cover. Unpin the HDD. Unpin the HDD.
    • Remove the HDD cover.
    • Unpin the HDD.
  3. Near to the WiFi card you can see one screw hole with a keyboard symbol. This screw holds the Keyboard. To remove the Keyboard, you must open 5X locking clips. To remove the Keyboard, you must open 5X locking clips.
    • Near to the WiFi card you can see one screw hole with a keyboard symbol. This screw holds the Keyboard.
    • To remove the Keyboard, you must open 5X locking clips.
  4. Under the Keyboard there are: 4x M2.5x5.0 screws Mouse flex cable connector
    • Under the Keyboard there are:
    • 4x M2.5x5.0 screws
    • Mouse flex cable connector
    • Power On button flex cable connector.
    • Unscrew the screws on the bottom side of the laptop:
    • 13x M2.5x5.0
    • 3x M2.5x3.0
  5. Use a plastic tool to separate and remove the upper case. Unscrew 5x screws and disconnect: LCD Display cable
    • Use a plastic tool to separate and remove the upper case.
    • Unscrew 5x screws and disconnect:
    • LCD Display cable
    • Additional USB board cable
    • Power jack cable
    • Loudspeaker cable
    • SATA HDD cable
  6. Move a little the LCD display hinge. Remove the board by starting from the right side. Remove the board by starting from the right side.
    • Move a little the LCD display hinge.
    • Remove the board by starting from the right side.
  7. Remove the cooling system. Remove the cooling system. Remove the cooling system.
    • Remove the cooling system.
  8. Open the fan and clean the dust from inside with a soft brush. Open the fan and clean the dust from inside with a soft brush.
    • Open the fan and clean the dust from inside with a soft brush.
  9. Clean the old thermal compound (from the CPU and from the heat-sink system). Put a new thermal compound and start with reassembling. Put a new thermal compound and start with reassembling.
    • Clean the old thermal compound (from the CPU and from the heat-sink system).
    • Put a new thermal compound and start with reassembling.
  10. When you start the system, check that fan is working. . Did you do it successfully?
9 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
177 366 Réputation
316 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
294 membres
963 tutoriels rédigés
A brilliant demonstration really clear and well photographed, only one problem how the !&&* do you get the screws undone mine seem fixed solid
please let me into the secret if there is one.
thanks for the demo anyway.
JF.
alma francomb - Réponse
Thanks for this!
My Son and I have just successfully removed, cleaned and replaced the fan in his laptop by following the instructions above.
Great work.
David Cooper - Réponse
Thank you a lot !!!!
lone guldbæk kvist - Réponse
I think i did something wrong? I completed all the steps but my fan (which is brand new) keeps making this scary loud wizzy noise instead of a hum and did i not tightem the screws enough or they to tight?? Please help!
Layla - Réponse
I can’t remove the laptop fan screw because they are too small, what are other alternative if you don’t have one of those small screwdriver?
mkgabudi - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 25
30 derniers jours : 128
Total : 21,657
