Aller au contenu principal
Compaq Presario CQ60-211DX Display Assembly Replacement
Ce dont vous avez besoin
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: étape 1, image 1 de 1
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: étape 2, image 1 de 2 Compaq Presario CQ60-211DX Display Assembly Replacement: étape 2, image 2 de 2
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: étape 3, image 1 de 2 Compaq Presario CQ60-211DX Display Assembly Replacement: étape 3, image 2 de 2
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: étape 4, image 1 de 1
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: étape 5, image 1 de 1
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: étape 6, image 1 de 1
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: étape 7, image 1 de 1
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
Garrett Carter
Membre depuis le 09/21/18
471 Réputation
4 tutoriels rédigés
Équipe
2 commentaires
My laptop model Compaq predario cq61 h
Rashid 007 - Réponse
Computer on but display light of computer is running
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 1,085
