Aller au contenu principal
Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement
Ce dont vous avez besoin
  1. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Handle Cover: étape 1, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Handle Cover: étape 1, image 2 de 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 2, image 1 de 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Dryer Head: étape 3, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Dryer Head: étape 3, image 2 de 2
    • Remove the inner white disk piece by gently pulling it out with your finger nail.
  4. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 4, image 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 4, image 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 4, image 3 de 3
    • Gently remove the tan boxes (power supply) by wiggling them out of place and set them aside so you can take the back part of the handle off.
  5. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 5, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 5, image 2 de 2
    • Remove the inner white disk piece from the base of the dryer head by gently pulling it out with your finger nail.
  6. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 6, image 1 de 1
    • Unscrew the three 12 mm long Phillips #2 screws to remove the back of the hairdryer.
  7. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 7, image 1 de 1
    • Once the three screws are removed, pop the back of the dryer off by wiggling it until it comes loose. This shouldn't take too much effort.
    Fantastic detail you provide. Thanks. Although I am generally good at this time of thing, reassembly would have been most difficult had it not been for your post. You saved my day. Again thank you. Dryer now clean and up and running as if new.
    James Shaw - Réponse
  8. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 8, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 8, image 2 de 2
    • Unwind the cord and lay it to the side so you can get to the screw in the middle easier.
    • Remove the single 12 mm long Phillips #2 screw in the middle of the cord track.
  9. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 9, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 9, image 2 de 2
    • Take off the white cap that covers the heating coil. You will see a wound up piece of metal (cord retracting coil) underneath once the cap is removed.
  10. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 10, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 10, image 2 de 2
    • When removing the coil, make sure it stays wound up. It could very easily pop out, and you would have to wind it all the way back up and try to squeeze it back into the slot when you reassemble the dryer.
    • To remove the coil, use your screw driver to pop the coil out of the slot.
    • The second image is what the coil would look like if it came undone when you removed it.
    What is simplest way to rewind cord? Mine looked like the second image when I got that far with removing the parts. It was already a tangled mess. I am going to try and rewind. Where do the bent ends of the coil go? I have started with putting one in groved slot....but if even can get it wound tight enough....I don't see where the other bend would go. Thank you, Susan
    Susan Letham - Réponse
  11. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 11, image 1 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 11, image 2 de 3 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement: étape 11, image 3 de 3
    • Once the coil is removed, unscrew the three 11 mm long Phillips #2 screws underneath to remove the retracting wheel.
  12. Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Cord Retracting Mechanism: étape 12, image 1 de 2 Conair Cord-Keeper 169XR Cord Retracting Mechanism Replacement, Cord Retracting Mechanism: étape 12, image 2 de 2
    • Remove the two parts of the retracting wheel.
Candace
Membre depuis le 01/23/14
992 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-33, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 membres
7 tutoriels rédigés
Un commentaire
Nicely done, just a suggestion, in Step #10 would suggest using fingers or flat object on top of spring when disengaging from frame …to ensure it won’t unravel and jump (as shown in 2nd picture + have some strong tape, string, wire ties, etc. to keep the spring wound up. This works for me when dealing with lawn mower recoil mechanism or tape measures. Tape measures are the worst to work on. lol - AHNauss
Howard - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 59
Total : 6,469
