Aller au contenu principal
Conair Infiniti PRO Curling Iron Heating Element Replacement
Ce dont vous avez besoin
  1. Conair Infiniti PRO Curling Iron Heating Element Replacement, Housing: étape 1, image 1 de 1
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Heating Element Replacement: étape 2, image 1 de 1
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Heating Element Replacement: étape 3, image 1 de 3 Conair Infiniti PRO Curling Iron Heating Element Replacement: étape 3, image 2 de 3 Conair Infiniti PRO Curling Iron Heating Element Replacement: étape 3, image 3 de 3
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Heating Element Replacement, Power Cord: étape 4, image 1 de 1
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Heating Element Replacement, Motherboard: étape 5, image 1 de 1
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Heating Element Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    Desoldering Pump
    $3.99
    J'achète
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Heating Element Replacement: étape 7, image 1 de 1
    • Once both wires are desoldered the motherboard can be removed.
  8. Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: étape 8, image 1 de 2 Conair Infiniti PRO Curling Iron Heating Element Replacement, Heating Element: étape 8, image 2 de 2
    • Remove the heating element mount. This will free up the heating element barrel for replacement.
3 autres ont terminé cette réparation.
Jonathon Bruer
Membre depuis le 11/09/17
607 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S7-G5, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S7-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 25
Total : 1,516
