Aller au contenu principal
Conair Infiniti PRO Spin Air Brush Circuit Board Replacement
Ce dont vous avez besoin
  1. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement, Circuit Board: étape 1, image 1 de 1
    • Look for the black screw covers near the top of the brush. Take the covers off with flat head screw driver.
  2. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the screws that secure the brush head.
  3. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 3, image 1 de 1
    • Gently take off the brush top.
  4. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 4, image 1 de 1
    • Take out the black gear by pulling up.
  5. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 5, image 1 de 1
    • Take the top of air filter off.
  6. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 6, image 1 de 1
    • Use flat head screwdriver to pop off the bottom air filter.
  7. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 7, image 1 de 1
    • Gently use a flat head screw driver to take of the black cover, covering the plastic shell.
  8. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 8, image 1 de 1
    • Using your flat head screwdriver to go along the seams of the plastic shell till the shell pops apart.
  9. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 9, image 1 de 1
    • Then take the switch cover and buttons off.
  10. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 10, image 1 de 1
    • Then take your Philips screw driver (ph1 size head) and unscrew the circuit board. The screw is located in the middle of the board.
  11. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: étape 11, image 1 de 1
    • Remove the black heater cover by sliding it off.
    • Desolder each of the four connections, and remove the circuit board.
andrew shirley
Membre depuis le 08/23/17
337 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G3, Freund Fall 2017 Membre de l'équipe IUPUI, Team S1-G3, Freund Fall 2017
IUPUI-FREUND-F17S1G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 39
Total : 594
