Aller au contenu principal
Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement
Ce dont vous avez besoin
  1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Back Panel: étape 1, image 1 de 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 2, image 1 de 2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 2, image 2 de 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 3, image 1 de 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 3, image 2 de 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 3, image 3 de 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: étape 4, image 1 de 2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: étape 4, image 2 de 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 5, image 1 de 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 5, image 2 de 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: étape 5, image 3 de 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
3 autres ont terminé cette réparation.
Timothy Lo
Membre depuis le 04/22/14
1 172 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-58, Amido Spring 2014 Membre de l'équipe Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 47
Total : 7,143
