Aller au contenu principal
  1. The parts depicted are the attachment pieces you should have (in addition to the conduit) The parts depicted are the attachment pieces you should have (in addition to the conduit)
    • The parts depicted are the attachment pieces you should have (in addition to the conduit)
  2. Pull the cover over the conduit and the wires Pull the cover over the conduit and the wires Pull the cover over the conduit and the wires
    • Pull the cover over the conduit and the wires
  3. Pull the outer yellow seal over the wires and the conduit The end with the ridge should be pulled down first (i.e. that end will be closer to the cover) The end with the ridge should be pulled down first (i.e. that end will be closer to the cover)
    • Pull the outer yellow seal over the wires and the conduit
    • The end with the ridge should be pulled down first (i.e. that end will be closer to the cover)
  4. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  5. Pull this piece over the wires and then screw it into the conduit Pull this piece over the wires and then screw it into the conduit Pull this piece over the wires and then screw it into the conduit
    • Pull this piece over the wires and then screw it into the conduit
  6. Put the connector piece into the node (may have to hold it in place for the subsequent steps) Put the connector piece into the node (may have to hold it in place for the subsequent steps) Put the connector piece into the node (may have to hold it in place for the subsequent steps)
    • Put the connector piece into the node (may have to hold it in place for the subsequent steps)
  7. Pull the yellow seal over the inside of the connector piece Pull the yellow seal over the inside of the connector piece Pull the yellow seal over the inside of the connector piece
    • Pull the yellow seal over the inside of the connector piece
  8. Screw the tightener piece onto the connector Screw the tightener piece onto the connector Screw the tightener piece onto the connector
    • Screw the tightener piece onto the connector
  9. Pull the wires through the connector piece and then screw the conduit onto the connector Pull the wires through the connector piece and then screw the conduit onto the connector Pull the wires through the connector piece and then screw the conduit onto the connector
    • Pull the wires through the connector piece and then screw the conduit onto the connector
  10. This is how it should look after everything is connected
    • This is how it should look after everything is connected
Nicholas Jeng
Membre depuis le 16/01/2018
529 Réputation
3 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 15
