Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Connect Four Electronic Handheld Buttons Replacement
Ce dont vous avez besoin
    1. Connect Four Electronic Handheld Buttons Replacement, Ensure the device is off.: étape 1, image 1 de 1
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      Demander à FixBot
      Ajouter un commentaire
    2. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: étape 2, image 1 de 2 Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: étape 2, image 2 de 2
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      Demander à FixBot
    1. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: étape 3, image 1 de 2 Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: étape 3, image 2 de 2
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      Demander à FixBot
    1. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: étape 4, image 1 de 3 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: étape 4, image 2 de 3 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: étape 4, image 3 de 3
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a spudger, lever the circuit board just enough to where you can easily access the button sheet.
      Demander à FixBot
    2. Connect Four Electronic Handheld Buttons Replacement, Removing/ Replacing the Button Sheet: étape 5, image 1 de 1
      • Take out the button sheet, and replace it with a new one.
      Demander à FixBot
Julia Wyder
Membre depuis le 10/22/14
110 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team 8-11, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 28
Total : 702
