Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Convert a 360 (Fat) hard drive into a 360 S hard drive
Ce dont vous avez besoin
    1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Change note: étape 1, image 1 de 2 Convert a 360 (Fat) hard drive into a 360 S hard drive, Change note: étape 1, image 2 de 2
      Outil utilisé dans cette étape :
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Demander à FixBot
      Ajouter un commentaire
    1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: étape 2, image 1 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: étape 2, image 2 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: étape 2, image 3 de 3
      • EET owners: Your kit has this bit. No purchase needed.
      • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
      • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
      • Remove the warranty seal and final screw. Use a T6 Torx driver.
      Demander à FixBot
    2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: étape 3, image 1 de 1
      • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
      • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
      Demander à FixBot
    3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: étape 4, image 1 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: étape 4, image 2 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: étape 4, image 3 de 3
      • If you are taking the enclosure apart for the bare drive, less caution is needed.
      • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
      • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
      Demander à FixBot
    4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: étape 5, image 1 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: étape 5, image 2 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: étape 5, image 3 de 3
      • Remove the four T10 Torx screws securing the hard drive.
      • After removing the screws, slide the top cover off and disconnect the drive.
      • Disconnect the hard drive and remove it from the enclosure.
      Demander à FixBot
    1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: étape 6, image 1 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: étape 6, image 2 de 3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: étape 6, image 3 de 3
      • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
      • After removing the drive from the old enclosure, open the new enclosure.
      • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
      • Close the enclosure and install it in your console.
      Demander à FixBot
Ligne d'arrivée
3 autres ont terminé cette réparation.
Nick
Membre depuis le 11/10/09
106 371 Réputation
72 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 55
30 derniers jours : 219
Total : 6,169
