Introduction
Allez à l'étape 1 ↓Use this guide to remove the core assembly in your TicWatch Pro.
Ce dont vous avez besoin
Outils
Spudger4.9
Before starting repairs, take your watch off the charger and power it down.
Remove the four 3.9 mm-long Torx T3 screws.
Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
Repair didn’t go as planned? Check out our Answers community for help.
4 autres ont terminé cette réparation.
1 commentaire de tutoriel
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
