Aller au contenu principal
Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement
Ce dont vous avez besoin
  1. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Glide Pads: étape 1, image 1 de 2 Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Glide Pads: étape 1, image 2 de 2
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Use the heat gun on the bottom of the mouse to loosen the glue on the pads.
    • Repeat this step with the other glide pads.
  2. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Mouse Nano-Switches: étape 2, image 1 de 1
    • Remove the two screws from the bottom of the mouse using a T5 Torx screwdriver.
  3. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: étape 3, image 1 de 1
    • Gently pry open the mouse shell using an iFixit opening tool.
    • Be careful not to force anything or use excessive force, as you may damage the components inside the mouse.
  4. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: étape 4, image 1 de 1
    • Use an iFixit opening tool to gently pry up the right and left click buttons on the top cover of the mouse until they pop out of place.
    • Be careful not to damage the wiring harnesses that connect the buttons to the PCB.
  5. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: étape 5, image 1 de 1
    • Use an iFixit opening tool to gently lift the top cover from the mouse body.
    • Be careful not to damage the wires connecting the cover to the mouse PCB.
  6. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: étape 6, image 1 de 1
    • Using a plastic opening tool, gently pry up the side button assemblies until they pop out of place.
  7. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: étape 7, image 1 de 1
    • Remove the screws that hold the circuit board in place using a Phillips #0 screwdriver.
    • Gently lift the PCB and set it aside.
  8. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • With the nano-switches now exposed, use a soldering iron to melt the solder holding the old switches in place.
    • Use tweezers to carefully remove the old switches and desolder any remaining solder.
Enzo Mello e Silva
Membre depuis le 02/09/23
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 56
Total : 626
