Aller au contenu principal
Corsair M55 RGB Pro Gaming Mouse Motherboard
Ce dont vous avez besoin
  1. Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: étape 1, image 1 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: étape 1, image 2 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: étape 1, image 3 de 3
    • Use a spudger to gently peel off and remove the three mouse feet on the bottom of the mouse.
    • If you are not replacing the mouse feet with a new set, put them aside to replace them at the end of the repair.
  2. Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 2, image 1 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 2, image 2 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws from the bottom of the mouse.
    • There is a cable connecting the bottom and top of the mouse.
  3. Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 3, image 1 de 2 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 3, image 2 de 2
    • Use a spudger to separate the top and bottom of the mouse.
    • Don't pull them apart as they are connected by a cable connector and could become damaged.
    • Pull the PCB cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  4. Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 4, image 1 de 2 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 4, image 2 de 2
    • Pull the USB pin cable away from the connector in the same direction as the individual wires are running.
  5. Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 5, image 1 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 5, image 2 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 5, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws that secure the motherboard.
  6. Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 6, image 1 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 6, image 2 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 6, image 3 de 3
    • Carefully lift the motherboard out of the base of the mouse by the edges.
  7. Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 7, image 1 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 7, image 2 de 3 Corsair M55 RGB Pro Gaming Mouse Motherboard: étape 7, image 3 de 3
    • If necessary, remove the mouse wheel by sliding it to the right.
    • It should come out of the slot easily as it's not attached.
Rizza Barnwell
Membre depuis le 03/05/24
145 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 8-11, Grodsky Spring 2024 Membre de l'équipe CSU Los Angeles, Team 8-11, Grodsky Spring 2024
CSULA-GRODSKY-S24S8G11
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 14
30 derniers jours : 24
Total : 62
