Aller au contenu principal
Cosori Pro II Heating Coil Replacement
Ce dont vous avez besoin
  1. Cosori Pro II Heating Coil Replacement, Shell: étape 1, image 1 de 1
    • Flip the device upside down and remove all of the Phillips #1 screws.
  2. Cosori Pro II Heating Coil Replacement: étape 2, image 1 de 2 Cosori Pro II Heating Coil Replacement: étape 2, image 2 de 2
    • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
    • Remove the panel.
  3. Cosori Pro II Heating Coil Replacement: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver to remove all four screws.
    • Lift off the bracket.
    • When lifting this off be careful to not unplug the screen.
  4. Cosori Pro II Heating Coil Replacement: étape 4, image 1 de 2 Cosori Pro II Heating Coil Replacement: étape 4, image 2 de 2
    • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
    • Dissemble the shell going up to separate the basket holder.
  5. Cosori Pro II Heating Coil Replacement: étape 5, image 1 de 2 Cosori Pro II Heating Coil Replacement: étape 5, image 2 de 2
    • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
    • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
  6. Cosori Pro II Heating Coil Replacement: étape 6, image 1 de 2 Cosori Pro II Heating Coil Replacement: étape 6, image 2 de 2
    • Pull the bottom shell down pulling at the sides to get them over screw holes.
  7. Cosori Pro II Heating Coil Replacement, Heating Coil: étape 7, image 1 de 1
    • Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
    • Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
  8. Cosori Pro II Heating Coil Replacement: étape 8, image 1 de 2 Cosori Pro II Heating Coil Replacement: étape 8, image 2 de 2
    • Flip the device backward so the metal walls appear in a U-shape.
    • Remove the 3 screws inside the cooking chamber that hold the heating coil in place using a 2 Philips screwdriver.
    • Remove the heating coil.
2 autres ont terminé cette réparation.
Davian E. Aguilera
Membre depuis le 08/28/24
241 Réputation
2 tutoriels rédigés
Équipe
2 commentaires
Le ventilateur démarre pas , c’est quoi le problème ?
amine _agm - Réponse
Does anyone know what´s reference of ic1 is on the distribution board? IC1 Image
Helio Goncalves - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 55
Total : 144
