Ce dont vous avez besoin
Remove the screws holding the cables into the distribution board with a Phillips #2 screwdriver.
Remove the 2 cables that connect the heating coil to the distribution board on the top of the cooking chamber, there should be one blue and one white cable, both with a white shroud leading into the cooking chamber.
Unhook the wires from the plastic hook.
Remove the two Phillips #2 screws that secure the blue and pink cables.
Use a Phillips #1 screwdriver to remove the single screw.
