Aller au contenu principal
Cosori Pro II Shell Replacement
Ce dont vous avez besoin
  1. Cosori Pro II Shell Replacement, Shell: étape 1, image 1 de 1
    • Flip the device upside down and remove all of the Phillips #1 screws.
  2. Cosori Pro II Shell Replacement: étape 2, image 1 de 2 Cosori Pro II Shell Replacement: étape 2, image 2 de 2
    • Use an opening tool to push on the retaining hooks to disengage them while prying slightly.
    • Remove the panel.
  3. Cosori Pro II Shell Replacement: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver to remove all four screws.
    • Lift off the bracket.
    • When lifting this off be careful to not unplug the screen.
  4. Cosori Pro II Shell Replacement: étape 4, image 1 de 2 Cosori Pro II Shell Replacement: étape 4, image 2 de 2
    • Use a Phillips #0 screwdriver to remove all the screws connecting to the shell.
    • Dissemble the shell going up to separate the basket holder.
  5. Cosori Pro II Shell Replacement: étape 5, image 1 de 2 Cosori Pro II Shell Replacement: étape 5, image 2 de 2
    • Use a Phillips #0 screwdriver and the 150 mm Flex Extension to unscrew the bottom plastic connecting to the basket holder.
    • Be careful to not apply too much force to the metal as it can cause it to warp it, and so it is easy rescrew the plastic piece in place.
  6. Cosori Pro II Shell Replacement: étape 6, image 1 de 2 Cosori Pro II Shell Replacement: étape 6, image 2 de 2
    • Pull the bottom shell down pulling at the sides to get them over screw holes.
Matthewmm
Membre depuis le 08/28/24
335 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 37
Total : 106
