Introduction
Before you can replace the joystick function of the device, follow the same steps as if you were replacing the Display Screen.
Ce dont vous avez besoin
Unscrew the four (4) screws using the PH000 drill bit from the iFixit toolkit.
Use the plastic opening tool from the iFixit toolkit to separate the back from the front of the device. This can be done by wedging the opening tool into the space where the two sides of the cover on the device meet.
After the plastic opening tool is wedged into the space, push down on the exposed end until the two sides come apart.
