Aller au contenu principal
Craftsman Model 315.10721 Switch Replacement
Ce dont vous avez besoin
  1. Craftsman Model 315.10721 Switch Replacement, Switch: étape 1, image 1 de 1
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
  2. Craftsman Model 315.10721 Switch Replacement: étape 2, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the 1/2" silver screw that is securing the switch.
  3. Craftsman Model 315.10721 Switch Replacement: étape 3, image 1 de 1
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the switch are plugged in.
    • Release both sets of the black and white wires and gently pull them from the leads.
    • To install the new switch, insert the wires of the new cord in the same way that they were removed.
Riley Hilliker
Membre depuis le 10/14/14
557 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-47, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 10
Total : 1,304
