Aller au contenu principal
Craig Electronics CMP773 Volume/Power Control Button Replacement
Ce dont vous avez besoin
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: étape 1, image 1 de 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: étape 2, image 1 de 1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: étape 3, image 1 de 1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: étape 4, image 1 de 1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: étape 5, image 1 de 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: étape 5, image 2 de 2
    • Remove the old button and replace it with the new one.
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
Membre depuis le 03/26/18
171 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G5, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 186
