Aller au contenu principal
Crayola Crayon Maker Light Bulb Removal and Replacement
Ce dont vous avez besoin
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: étape 1, image 1 de 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: étape 1, image 2 de 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: étape 1, image 3 de 3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: étape 2, image 1 de 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: étape 2, image 2 de 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: étape 2, image 3 de 3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: étape 3, image 1 de 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: étape 3, image 2 de 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: étape 3, image 3 de 3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Ligne d'arrivée
Heidi Clarke
Membre depuis le 09/21/14
222 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 33
Total : 6,543
