Aller au contenu principal
Creality Ender 3 V2 Extruder Nozzle Replacement
Ce dont vous avez besoin
  1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: étape 1, image 1 de 1
    • Move the extruder carriage to the center of the machine.
  2. Creality Ender 3 V2 Extruder Nozzle Replacement: étape 2, image 1 de 1
    • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
  3. Creality Ender 3 V2 Extruder Nozzle Replacement: étape 3, image 1 de 1
    • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
  4. Creality Ender 3 V2 Extruder Nozzle Replacement: étape 4, image 1 de 3 Creality Ender 3 V2 Extruder Nozzle Replacement: étape 4, image 2 de 3 Creality Ender 3 V2 Extruder Nozzle Replacement: étape 4, image 3 de 3
    • Remove the silicon sleeve around the heat block.
    • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
  5. Creality Ender 3 V2 Extruder Nozzle Replacement: étape 5, image 1 de 2 Creality Ender 3 V2 Extruder Nozzle Replacement: étape 5, image 2 de 2
    • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
    • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
  6. Creality Ender 3 V2 Extruder Nozzle Replacement: étape 6, image 1 de 3 Creality Ender 3 V2 Extruder Nozzle Replacement: étape 6, image 2 de 3 Creality Ender 3 V2 Extruder Nozzle Replacement: étape 6, image 3 de 3
    • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
    • If the nozzle is fully cooled, remove the nozzle.
  7. Creality Ender 3 V2 Extruder Nozzle Replacement: étape 7, image 1 de 2 Creality Ender 3 V2 Extruder Nozzle Replacement: étape 7, image 2 de 2
    • Screw on the new nozzle into the heat block with your wrench.
    • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
    • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
Print away!
7 autres ont terminé cette réparation.
Équipe
UMass Dartmouth, Team S2-G3, Riel Spring 2021 Membre de l'équipe UMass Dartmouth, Team S2-G3, Riel Spring 2021
UMASSD-RIEL-S21S2G3
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 129
30 derniers jours : 635
Total : 17,553
