Aller au contenu principal
Creative Nomad II Lock/Unlock Switch Replacement
Ce dont vous avez besoin
  1. Creative Nomad II Lock/Unlock Switch Replacement, Battery: étape 1, image 1 de 1
    • Using your thumb, slide down and remove the battery cover.
  2. Creative Nomad II Lock/Unlock Switch Replacement: étape 2, image 1 de 1
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Creative Nomad II Lock/Unlock Switch Replacement, Smart Media Card: étape 3, image 1 de 1
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Creative Nomad II Lock/Unlock Switch Replacement, Back Cover: étape 4, image 1 de 1
    • Using a Phillips #00 Screwdriver, remove the two 7.5mm screws from the sides of the back cover.
  5. Creative Nomad II Lock/Unlock Switch Replacement: étape 5, image 1 de 1
    • Lift the back cover off of the NOMAD II.
    • Remove the rubber USB port cover, the connected buttons along the left edge, and the plastic lock/unlock button on the upper right edge of the device.
  6. Creative Nomad II Lock/Unlock Switch Replacement, Battery Compartment: étape 6, image 1 de 1
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws from the sides of the battery compartment.
  7. Creative Nomad II Lock/Unlock Switch Replacement: étape 7, image 1 de 1
    • Carefully remove the battery compartment.
  8. Creative Nomad II Lock/Unlock Switch Replacement, Circuit Boards: étape 8, image 1 de 1
    • Using a Phillips #00 Screwdriver, remove the two 5.5mm screws on the left and right edges of the circuit board.
  9. Creative Nomad II Lock/Unlock Switch Replacement: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, carefully pry the metal loop on the left side of the battery compartment away from the case.
  10. Creative Nomad II Lock/Unlock Switch Replacement: étape 10, image 1 de 1
    • Pull the circuit boards out of the back cover.
    • During reinstallation, firmly press the top of the circuit boards into the cover until you hear a click.
  11. Creative Nomad II Lock/Unlock Switch Replacement: étape 11, image 1 de 1
    • Gently pry the circuit boards apart.
    • This must be done with the USB port facing up, as shown.
  12. Creative Nomad II Lock/Unlock Switch Replacement, Lock/Unlock Switch: étape 12, image 1 de 1
    • Desolder the seven solder joints which hold the lock switch in place.
    • Install the new lock/unlock switch.
Craig Fischer
Membre depuis le 01/24/12
21 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-2, Regan Winter 2012 Membre de l'équipe Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,845
