Aller au contenu principal
Creative Zen V Plus Headphone Jack Replacement
Ce dont vous avez besoin
  1. Creative Zen V Plus Headphone Jack Replacement, Prerequisite Only: étape 1, image 1 de 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Headphone Jack Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Headphone Jack Replacement: étape 3, image 1 de 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Headphone Jack Replacement: étape 4, image 1 de 2 Creative Zen V Plus Headphone Jack Replacement: étape 4, image 2 de 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Headphone Jack Replacement: étape 5, image 1 de 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Headphone Jack Replacement: étape 6, image 1 de 3 Creative Zen V Plus Headphone Jack Replacement: étape 6, image 2 de 3 Creative Zen V Plus Headphone Jack Replacement: étape 6, image 3 de 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Headphone Jack Replacement, Headphone Jack: étape 7, image 1 de 1
    • Locate the circles of metal holding the headphone jack to the logic board. Using a soldering iron, de-solder these circles and remove the headphone jack.
Joshua Meines
Membre depuis le 10/19/16
316 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 2-5, Baechle Fall 2016 Membre de l'équipe IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 282
