Aller au contenu principal
Introduction
This guide will show you how to remove the front cover of your device. Use this guide to gain access to the button pad and LCD screen.
Pièces
Aucune pièce spécifiée.
  1. Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
    • Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
  2. Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
    • Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
  3. Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen. When the cover has been lifted off the screen, use your hands to remove it from the device. The button pad may fall off when the cover is removed.
    • Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
    • When the cover has been lifted off the screen, use your hands to remove it from the device.
    • The button pad may fall off when the cover is removed.
Gabriele Pregadio
Membre depuis le 17/04/2013
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-2, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 membres
8 tutoriels rédigés
Un commentaire
Fantastic but does anyone know where I can get this part?
VegetaFlex4Fitness - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 326
