Aller au contenu principal
Introduction
This guide will show you how to remove and install a new LCD screen in your device. Use this guide if your screen is broken or damaged and needs to be replaced.
  1. Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
    • Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
  2. Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
    • Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
  3. Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen. When the cover has been lifted off the screen, use your hands to remove it from the device. The button pad may fall off when the cover is removed.
    • Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
    • When the cover has been lifted off the screen, use your hands to remove it from the device.
    • The button pad may fall off when the cover is removed.
  4. Use a spudger to separate the metal tabs that hold the screen in place on the right side. The screen is still attached underneath with two ribbon cables.  Lift it very carefully. The screen is still attached underneath with two ribbon cables.  Lift it very carefully.
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  5. Put the screen face down so you can see where the ribbon cables are attached.
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  6. Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  7. Use a spudger to slide the two small gray tabs away from the ribbon cable connection. Remove the screen from the device. Remove the screen from the device.
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
Tim Wilson
Membre depuis le 11/04/2013
128 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 17-2, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 membres
8 tutoriels rédigés
Un commentaire
Where can I get the screen
Home Watch - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,240
