Aller au contenu principal
Creative Zen X-Fi LCD Screen Replacement
Ce dont vous avez besoin
  1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: étape 1, image 1 de 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: étape 1, image 2 de 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: étape 1, image 3 de 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: étape 2, image 1 de 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: étape 3, image 1 de 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: étape 4, image 1 de 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: étape 5, image 1 de 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: étape 6, image 1 de 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: étape 7, image 1 de 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: étape 8, image 1 de 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: étape 8, image 2 de 2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
  9. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: étape 9, image 1 de 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: étape 9, image 2 de 2
    • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
  10. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: étape 10, image 1 de 1
    • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
    • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
3 autres ont terminé cette réparation.
Westley Courchene
Membre depuis le 01/13/15
3 410 Réputation
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 23
Total : 1,740
