Aller au contenu principal
Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
Ce dont vous avez besoin
  1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: étape 1, image 1 de 1
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 2, image 1 de 1
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 3, image 1 de 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 3, image 2 de 2
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
  4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: étape 4, image 1 de 3 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: étape 4, image 2 de 3 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: étape 4, image 3 de 3
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: étape 5, image 1 de 1
    • Remove the inner pot and set it aside for reassembly.
  6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 6, image 1 de 1
    • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
    • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
  7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 7, image 1 de 1
    • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
  8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 8, image 1 de 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 8, image 2 de 2
    • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
  9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 9, image 1 de 1
    • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
  10. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 10, image 1 de 1
    • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
    • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
  11. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 11, image 1 de 1
    • Reorient the crockpot on its side to prepare for the heating element removal.
  12. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 12, image 1 de 1
    • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
  13. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 13, image 1 de 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: étape 13, image 2 de 2
    • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
    • Carefully remove the heating element from the device.
Un commentaire
where do you get a heating element?
Stephanie Brown - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 36
Total : 4,548
