Aller au contenu principal
Crosley CR42 Bushings Replacement
Ce dont vous avez besoin
  1. Crosley CR42 Bushings Replacement, Bushings: étape 1, image 1 de 2 Crosley CR42 Bushings Replacement, Bushings: étape 1, image 2 de 2
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: étape 2, image 1 de 3 Crosley CR42 Bushings Replacement: étape 2, image 2 de 3 Crosley CR42 Bushings Replacement: étape 2, image 3 de 3
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: étape 3, image 1 de 3 Crosley CR42 Bushings Replacement: étape 3, image 2 de 3 Crosley CR42 Bushings Replacement: étape 3, image 3 de 3
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: étape 4, image 1 de 2 Crosley CR42 Bushings Replacement: étape 4, image 2 de 2
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: étape 5, image 1 de 1
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: étape 6, image 1 de 3 Crosley CR42 Bushings Replacement: étape 6, image 2 de 3 Crosley CR42 Bushings Replacement: étape 6, image 3 de 3
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: étape 7, image 1 de 2 Crosley CR42 Bushings Replacement: étape 7, image 2 de 2
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: étape 8, image 1 de 3 Crosley CR42 Bushings Replacement: étape 8, image 2 de 3 Crosley CR42 Bushings Replacement: étape 8, image 3 de 3
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
Roberto Rosila
Membre depuis le 01/26/14
319 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-38, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 16
Total : 2,839
