Aller au contenu principal
Crosley CR42 Power Cable Replacement
Ce dont vous avez besoin
  1. Crosley CR42 Power Cable Replacement, Power Cable: étape 1, image 1 de 2 Crosley CR42 Power Cable Replacement, Power Cable: étape 1, image 2 de 2
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: étape 2, image 1 de 3 Crosley CR42 Power Cable Replacement: étape 2, image 2 de 3 Crosley CR42 Power Cable Replacement: étape 2, image 3 de 3
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: étape 3, image 1 de 3 Crosley CR42 Power Cable Replacement: étape 3, image 2 de 3 Crosley CR42 Power Cable Replacement: étape 3, image 3 de 3
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: étape 4, image 1 de 3 Crosley CR42 Power Cable Replacement: étape 4, image 2 de 3 Crosley CR42 Power Cable Replacement: étape 4, image 3 de 3
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: étape 5, image 1 de 3 Crosley CR42 Power Cable Replacement: étape 5, image 2 de 3 Crosley CR42 Power Cable Replacement: étape 5, image 3 de 3
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: étape 6, image 1 de 3 Crosley CR42 Power Cable Replacement: étape 6, image 2 de 3 Crosley CR42 Power Cable Replacement: étape 6, image 3 de 3
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: étape 7, image 1 de 3 Crosley CR42 Power Cable Replacement: étape 7, image 2 de 3 Crosley CR42 Power Cable Replacement: étape 7, image 3 de 3
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Eric Dybsetter
Membre depuis le 01/26/14
175 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-38, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 26
Total : 6,005
