Aller au contenu principal
Crosley CR704 Speaker Replacement
Ce dont vous avez besoin
  1. Crosley CR704 Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
  2. Crosley CR704 Speaker Replacement: étape 2, image 1 de 1
    • Gently remove the back panel of the device being careful not to unplug any internal wires.
  3. Crosley CR704 Speaker Replacement: étape 3, image 1 de 1
    • Using your Phillips head screwdriver, remove the 4 brass speaker screws.
    • Be careful to not remove the speaker housing screws, which surround the speaker screws.
  4. Crosley CR704 Speaker Replacement: étape 4, image 1 de 1
    • Carefully pull the wires out of their connections from the back of the speaker.
    • Don't forget which wire goes with which connection!
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
MarkAnthony
Membre depuis le 09/22/13
772 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013 Membre de l'équipe UMass Dartmouth, Team 1-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G4
3 membres
5 tutoriels rédigés
Un commentaire
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
ninjadaniel66 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 26
Total : 2,853
