Aller au contenu principal
Crosley CR8005A Belt Replacement
Ce dont vous avez besoin
  1. Crosley CR8005A Belt Replacement, Belt: étape 1, image 1 de 1
    • Remove the slipmat and locate the small, round clip which holds the turntable platter to the turntable.
    • Insert the iFixit opening tool between the spindle and the clip and pry off the clip.
    • The clip does not need to be replaced and might already be missing.
  2. Crosley CR8005A Belt Replacement: étape 2, image 1 de 1
    • After removing the clip, lift the turntable platter off the chrome spindle on the turntable base. The band connects the platter to the turntable base and will likely fall off in this process.
    • There will be some lubricant on the band and the metal prong on the turntable base. Leave this lubricant as is.
  3. Crosley CR8005A Belt Replacement: étape 3, image 1 de 1
    • Turn the platter over so that you are looking at the underside.
    • Stretch the new band around the raised, internal circle and loop the band over the raised prong. This will create a teardrop shape with your new band.
    • Try not to over-stretch the new band or you will need to replace it too.
  4. Crosley CR8005A Belt Replacement: étape 4, image 1 de 1
    • Turn the platter back over and place it on the spindle.
    • Spin the platter 2 times clockwise to unloop the band from the raised prong on the platter and to loop it around the raised prong on the turntable base. This allows the circular motion of the motor to spin the band and the turntable platter.
    • You may replace the round clip at this point though it is not important to the sound quality of the turntable.
Now, spin some tunes and enjoy your improved sound!
4 autres ont terminé cette réparation.
Ramie Bell
Membre depuis le 10/30/19
249 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team S2-G3, Kim Fall 2019 Membre de l'équipe University of Memphis, Team S2-G3, Kim Fall 2019
UM-KIM-F19S2G3
4 membres
3 tutoriels rédigés
Un commentaire
what to do if you cannot lift up the platter in step 2.
Priyanka Baghaie - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 37
30 derniers jours : 182
Total : 12,868
