Introduction
If the volume knob on your Crosley Cruiser (CR8005A) is cracked, damaged, or having trouble turning, this guide will show you how to safely remove and replace it. (You can also remove the knob if you just want to inspect, clean, or customize it.)
The only tool required is a plastic opening tool or spudger.
Ce dont vous avez besoin
To put the knob back on, push the knob directly down onto its peg.
2 commentaires
Hi, how to change the actual know (not the plastic cover)?
As mine is faulty and I could use some help please haha
Digi-key part # similar to PTD908-1215K-B203-ND.
