Aller au contenu principal
Cruiser Bike Rear Wheel Replacement
Ce dont vous avez besoin
  1. Cruiser Bike Rear Wheel Replacement, Rear Wheel: étape 1, image 1 de 1
    • Flip your bike so the seat and handlebars are on the ground.
    • This will make it easier to access tire.
  2. Cruiser Bike Rear Wheel Replacement: étape 2, image 1 de 1
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel.
    • Handle the chain carefully to ensure a successful tire replacement.
  3. Cruiser Bike Rear Wheel Replacement: étape 3, image 1 de 1
    • Tighten brake strap using screwdriver and 10 mm socket wrench.
    • Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • You will know the socket wrench is has finished tightening when you feel resistance.
  4. Cruiser Bike Rear Wheel Replacement: étape 4, image 1 de 1
    • Center the wheel and pull back to tighten the chain.
    • If the bike wheel is unusable use tire levers to remove tire.
  5. Cruiser Bike Rear Wheel Replacement: étape 5, image 1 de 1
    • With the wheel pulled back, tighten the two axle nuts using the 15 mm socket wrench.
    • Tighten the non-drive side (side without the chain) first.
    • The wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
    • Use a tire pump to make sure the tire is full of air and ready to ride.
2 autres ont terminé cette réparation.
Erin Heimburge
Membre depuis le 07/11/13
36 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team 2-1, Bradley Spring 2013 Membre de l'équipe UC Santa Barbara, Team 2-1, Bradley Spring 2013
UCSB-BRADLEY-S13S2G1
4 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 35
Total : 11,602
