Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Cuisinart CPB-380 Disassembly
Ce dont vous avez besoin
    1. Cuisinart CPB-380 Disassembly, Cuisinart CPB-380 Disassembly: étape 1, image 1 de 3 Cuisinart CPB-380 Disassembly, Cuisinart CPB-380 Disassembly: étape 1, image 2 de 3 Cuisinart CPB-380 Disassembly, Cuisinart CPB-380 Disassembly: étape 1, image 3 de 3
      • Turn the device upside down.
      • Remove all four rubber feet by prying them out using the metal spudger.
      • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
      Demander à FixBot
      Ajouter un commentaire
    2. Cuisinart CPB-380 Disassembly: étape 2, image 1 de 2 Cuisinart CPB-380 Disassembly: étape 2, image 2 de 2
      • Remove the base from the body of the blender.
      Demander à FixBot
    3. Cuisinart CPB-380 Disassembly: étape 3, image 1 de 3 Cuisinart CPB-380 Disassembly: étape 3, image 2 de 3 Cuisinart CPB-380 Disassembly: étape 3, image 3 de 3
      • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
      • Gently move the wire aside so that it is not in the way.
      Demander à FixBot
    4. Cuisinart CPB-380 Disassembly: étape 4, image 1 de 3 Cuisinart CPB-380 Disassembly: étape 4, image 2 de 3 Cuisinart CPB-380 Disassembly: étape 4, image 3 de 3
      • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
      • Gently remove the black cover.
      • Underneath, you will see a clear plastic cover that should be removed as well.
      Demander à FixBot
    5. Cuisinart CPB-380 Disassembly: étape 5, image 1 de 2 Cuisinart CPB-380 Disassembly: étape 5, image 2 de 2
      • Cut the zip tie that holds the black, blue, red, and yellow wires together.
      • Take care not to cut the wires.
      Demander à FixBot
2 autres ont terminé cette réparation.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 35
Total : 1,150
