Introduction
This replacement guide will help you get through all of the top pieces such as the filter element to get to the drip spring. It is possible for this spring to break causing issues with the drip function or rust possibly causing a strange taste.
While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
Where can I purchase a replacement for that small gasket that holds the plunger in place
Remove the spring from the dripper.
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. My problem was not knowing how to replace this spring, but having lost it and needing to find a suitable spring to replace. There are several spring specialty websites, but the one that had the item I needed had a $40 minimum. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
8 autres ont terminé cette réparation.
4 commentaires
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
