Aller au contenu principal
Cuisinart DFP-14BCN Buttons Replacement
Ce dont vous avez besoin
  1. Cuisinart DFP-14BCN Buttons Replacement, Bowl: étape 1, image 1 de 3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: étape 1, image 2 de 3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: étape 1, image 3 de 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Buttons Replacement: étape 2, image 1 de 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Buttons Replacement: étape 3, image 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 3, image 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 3, image 3 de 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Buttons Replacement: étape 4, image 1 de 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Buttons Replacement: étape 5, image 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 5, image 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 5, image 3 de 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Buttons Replacement, Back Casing: étape 6, image 1 de 2 Cuisinart DFP-14BCN Buttons Replacement, Back Casing: étape 6, image 2 de 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Buttons Replacement: étape 7, image 1 de 2 Cuisinart DFP-14BCN Buttons Replacement: étape 7, image 2 de 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Buttons Replacement: étape 8, image 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 8, image 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 8, image 3 de 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Buttons Replacement: étape 9, image 1 de 2 Cuisinart DFP-14BCN Buttons Replacement: étape 9, image 2 de 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Buttons Replacement, Buttons: étape 10, image 1 de 3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: étape 10, image 2 de 3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: étape 10, image 3 de 3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Buttons Replacement: étape 11, image 1 de 2 Cuisinart DFP-14BCN Buttons Replacement: étape 11, image 2 de 2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Buttons Replacement: étape 12, image 1 de 1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Buttons Replacement: étape 13, image 1 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 13, image 2 de 3 Cuisinart DFP-14BCN Buttons Replacement: étape 13, image 3 de 3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
Sonya Dick
Membre depuis le 10/05/16
352 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-3, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 membres
7 tutoriels rédigés
Un commentaire
Is there a source for replacing the button assembly?
BadMahoney - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 17
Total : 1,104
