Introduction
If the Cuisinart DGB-650 power cable is cut, the prongs are bent, or the wire is fried, you need to replace the power cord. Make sure everything is unplugged from an outlet source to ensure you do not get shocked.
Ce dont vous avez besoin
Turn the coffee maker upside down.
Remove the four 1.2 mm screws using a Phillips #0 screwdriver.
Remove the bottom cover to expose the heating element and pipes.
