Aller au contenu principal
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
Ce dont vous avez besoin
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: étape 1, image 1 de 1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: étape 2, image 1 de 1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: étape 3, image 1 de 1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: étape 4, image 1 de 1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: étape 5, image 1 de 1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: étape 6, image 1 de 1
    • Fit the wires back into the motor base and place the new power cord in the slot.
By the end of this guide< you will have successfully replaced the power cord to your device.
Reagan Burns
Membre depuis le 04/02/15
119 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-1, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 24-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G1
2 membres
1 tutoriel rédigé
4 commentaires
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - Réponse
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - Réponse
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 10
Total : 1,628
