Introduction
This guide's purpose is to show you how to remove the switch from this type of food processor.
Ce dont vous avez besoin
Remove the four screws (circled in red) out of the bottom of the processor using a Philips #2 Screwdriver.
2 autres ont terminé cette réparation.
9 commentaires
Thanks for the guide. Where did you get the replacement switch? Thanks
Hey Riley,
Looks good, but where do I buy a replacement switch?
Yes, where does one buy a switch?
I recently disassembled my 25+ year old dcl10plus after no parts sites showed a “switch” before finding this website posting.
Turns out (as is clear in the posting) the actual electrical part of switch is not some fancy gizmo but a simple micro switch in a fancy gizmo.
The original is no longer made and is actually a very plain Jane switch. I found many expensive replacements that were typically $3-5 plus $7-8 shipping. A friend suggested checking banggood and found them sold in lots of 1, 2, 5, 10, 20 starting at about $1.50 including shipping but switch had additional “roller arm” which I assumed would just pop out. I order the two pack at $1.88.
The banggood search id on the item is 944612. I actually had to use a small hack saw to cut the arm as it didn’t pop out. Mine was a DCL10p the switch may vary in other models so disassemble before ordering. Also beware if you look at other sites … there are two sizes of electrical lugs that I saw on this size switch … this is the smaller one (match yours to banggod picture).
