Aller au contenu principal
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement
Ce dont vous avez besoin
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement, Switch: étape 1, image 1 de 1
    • Remove the four screws (circled in red) out of the bottom of the processor using a Philips #2 Screwdriver.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: étape 2, image 1 de 1
    • Remove the bottom casing of the food processor and set aside.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: étape 3, image 1 de 1
    • Remove the four screws (circled in red) holding the switch down.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: étape 4, image 1 de 1
    • Carefully pull the switch out of the device.
    • This step may take some time.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: étape 5, image 1 de 1
    • Remove the two screws from the switch (circled in red) attached by wires.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: étape 6, image 1 de 1
    • Remove the component (shown by the arrow in the picture to the left) attached to wires from the switch.
  7. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Switch Replacement: étape 7, image 1 de 1
    • Carefully remove and replace the switch, now that the wires are detached.
2 autres ont terminé cette réparation.
Riley Carns
Membre depuis le 04/02/15
279 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 24-1, Lancaster Winter 2015 Membre de l'équipe Cal Poly, Team 24-1, Lancaster Winter 2015
CPSU-LANCASTER-W15S24G1
1 membre
2 tutoriels rédigés
9 commentaires
Thanks for the guide. Where did you get the replacement switch? Thanks
Fran Fedoroff - Réponse
Hey Riley,
Looks good, but where do I buy a replacement switch?
Margaret Mealia - Réponse
Yes, where does one buy a switch?
Lori Girard - Réponse
I recently disassembled my 25+ year old dcl10plus after no parts sites showed a “switch” before finding this website posting.
Turns out (as is clear in the posting) the actual electrical part of switch is not some fancy gizmo but a simple micro switch in a fancy gizmo.
The original is no longer made and is actually a very plain Jane switch. I found many expensive replacements that were typically $3-5 plus $7-8 shipping. A friend suggested checking banggood and found them sold in lots of 1, 2, 5, 10, 20 starting at about $1.50 including shipping but switch had additional “roller arm” which I assumed would just pop out. I order the two pack at $1.88.
The banggood search id on the item is 944612. I actually had to use a small hack saw to cut the arm as it didn’t pop out. Mine was a DCL10p the switch may vary in other models so disassemble before ordering. Also beware if you look at other sites … there are two sizes of electrical lugs that I saw on this size switch … this is the smaller one (match yours to banggod picture).
Terry Schwarz - Réponse
I am hoping to find not the microswitch, but the plastic lever. How would you go about finding a replacement for that? Ours broke and we can turn the Cuisanart on/off by jamming a wooden spoon in there. There must be a better replacement though…
Bswx - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 9
Total : 1,932
