Aller au contenu principal
Cuisinart DLC-8F Automatic Circuit Breaker Replacement
Ce dont vous avez besoin
  1. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: étape 1, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Power Cable: étape 1, image 2 de 2
    • Remove the four 18 mm Phillips #2 screws from the bottom by prying up the rubber feet to access the screw hole.
  2. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 2, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 2, image 2 de 2
    • Gently lift the bottom cover from the main body.
  3. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 3, image 1 de 1
    • Remove the two 62 mm Phillips #2 screws from the cable retaining clip.
  4. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 4, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 4, image 2 de 2
    • Lift off the cable retaining
  5. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 5, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 5, image 2 de 2
    • Pull apart the two wires of the power cable at their connections as shown.
  6. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 6, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 6, image 2 de 2
    • Lift out the cable.
  7. Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: étape 7, image 1 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: étape 7, image 2 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement, Automatic Circuit Breaker: étape 7, image 3 de 3
    • Pull out the power cable screw stand with your hand.
  8. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 8, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 8, image 2 de 2
    • Remove the two 15 mm Phillips #2 screws on the automatic circuit breaker.
  9. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 9, image 1 de 2 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 9, image 2 de 2
    • Pull out the automatic circuit breaker with your hand.
  10. Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 10, image 1 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 10, image 2 de 3 Cuisinart DLC-8F Automatic Circuit Breaker Replacement: étape 10, image 3 de 3
    • Pull off the three wires by grabbing from the base of the wire.
David Colman
Membre depuis le 01/25/17
573 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 8-6, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 8-6, Banghart Winter 2017
CPSU-BANGHART-W17S8G6
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 574
